I have temporarily mounted my RH flap to check for clearance and have noticed one area of binding. You can see in the photo there is a hole in the leading edge of the flap that lines up with the head of an AN4 bolt which holds the flap torque tube. The hole and the bolt don’t line up exactly and are catching. Has anyone just opened up this hole up? Or is there another solution.
Mounting flaps
Mounting flaps
This gallery has 2 photos.Last edited by SimonNicholson; 10-14-2019, 11:46 PM.Tags: None
I opened up the hole. Another builder I know added large AN970 washers between the rear spar and the hinge mount iron to move the flap away from the spar.Last edited by Bcone1381; 10-15-2019, 07:43 PM.Brooks Cone
You can open up that hole in the leading edge of the flap so that bolt head clears. Putting washers under the weldments to move the entire flap back some is also possible but would not seem necessary to me. You would never just put washers under one weldment. You would need to do them all. Mark
You might find you need to elongate the hole. On my installation the bolt would catch in the hole when the flap began its travel. It would kind of click into place. So, I opened it up (elongated it) a bit so there was no contact with the flap leading edge passing by the bolt.Brooks Cone
