Dpearson
4-Place QB (A Model)
Well I tried to test-fit my aux tank from the top side of the wing, before cutting the hole in the bottom skin. Unfortunately the tanks (including the welded fittings) seem to be wider than the spacing between the ribs.
The Beartracks article from 1996 says the tank should be 13-1/4" wide. The ones I have are ~13-1/2" "wall-to-wall", and the welded fittings add another 1/2" or so, giving a total of 14". The spacing between the rib flanges is ~13-3/4", so the welded fittings can't make it past the rib flange.
Has anyone else encountered this? I'm wondering if these tanks (which I believe were manufactured back in 2006) are out of spec...
