I understand helicopters tend to have mostly vertical crashes, whereas fixed wing aircraft are a combination or horizontal (failure to get airborne or overrun landing). Many planes also overturn if landing on water, snow, or terrain, so negative g-force is a factor is many crashes. Regrettably, many pilots with a dead stick will stall it from 50ft if they find themselves without an "airstrip-like" surface to land upon. Potentially, that makes a survivable situation a whole lot worse.
Having reviewed a range of light single engine aircraft accidents over the years, I've noticed a trend. It seems the pilot often suffers worse injuries than the passengers because their hands/arms are at the controls instead of bracing themselves or protecting their face. Not much you can do about that. The other point of note is some accidents involve a bounce as the aircraft lands, and rumour has it that inertial reels sometimes unlock during the bounce, leading to injuries on the rebound. So I guess falling to the ground is less desirable than a controlled touchdown, but you already knew that. Also there' something about shoulder harnesses for the pilot in those two points.
But at the end of the day, it's all luck of the draw. Besides some generic parameters, there's no telling what kind of accident might occur. Provided you've got the basics right, like a strong airframe, a 3 or 4 point harness worn, no sharp objects in the cabin, and a secure load, then it's all about your decisions prior to impact. I would rather practice forced landings than invest in a shock absorbing seat that might provide a fraction more cushioning. How you put the plane down has a lot to do with the injuries you sustain.
