The rivets on all the skins overlaying each other are MS20426-4 and on the Spars MS 20246-3 AD, are the rivets on the other ribs also MS 20246-3 AD?
rivet size on ribs
Which model are you referring to? On the 4 place, the -4 rivets are used on the skin overlaps, main spar flange to center rib flange points, and also to rivet the .032" inboard skin to the spars. -3's everywhere else.Last edited by nichzimmerman; 01-22-2018, 03:40 PM.
Is the MS20426-4 an A or AD designation? I see the 20246-3 AD listed in places with the AD hardness, but nowhere can I find the -4 designation (and all supplier listings I see for the -4 is either an A or AD available) Thanks!
That's correct. "AD" rivets are tempered. "A" rivets are soft. Typically used in an application where you're going to weld over them, like in your fuel tanks. You wouldn't use an "A" rivet in a structural application.Christopher Owens
