As many of you know, I strived very hard to come in as light as possible with my Patrol. To that end, I had no electrical system and no luxuries.
My empty weight, came in at 1,061 lbs and a CG of 12.8"
Last week I took a week of vacation and installed a minimal electrical system. Again, my goal was to do it as light as possible. So what did having the luxury of a starter, battery and alternator cost me in weight gain? Well, it came in at exactly 30 lbs. all together.
Here is what I added:
Flywheel = 7 lbs.
Skytec Starter = 7 lbs
B&C Alternator = 3 lbs
Regulator = 2 lbs
Lithium Ion Battery = 6 lbs
Battery Box and mount = 1 lbs
Fuse Block and Fuses = 1 lbs
Wires, Switches,
Connectors, etc. = 3 lbs
Total 30 lbs.
So for a minimal system it added 30 lbs to my airplane. I re-weighed my airplane and its actually 42 lbs heavier. the extra 12 lbs came from the tires that I changed to. I previously had 6.00 x 6 AirHawk tires and later put on some 8.00 x 6 Goodyears. The Goodyears are about 6lbs heavier per tire, so that means an additional12 Lbs for the two.
So now my empty weight is 1103 lbs and the CG is 11.3"
Is it worth it? To me it is. It feels really good to be able to not have to tie down the tail, prop start it, untie the tail and then try to get in it before it taxies away without me. As an added bonus, I don't have to haul batteries and chargers for my GPS, radio, etc. back and forth. Now I get to just pre-flight, get in and go flying. I love it.
Flywheel = 7 lbs.
Regulator = 2 lbs
Wires, Switches,
Total 30 lbs.
Eric Newton - Long Beach, MS
