I am finishing up the rebuild on Bob's LSA. Been having some issues with the tachometer he wants to use. It is PN# TLP14 from Aircraft Spruce. So far I have tried everything Bob and I can think of to get it to work. It is a lightweight unit (only 65 grams...) has an internal battery, simple to hook up...only two wires, one is ground to the engine and the other (a induction/signal wire) wraps around a plug wire. The thing acutally does work, BUT the readings are all over the place....at mid range throttle, I am seeing readings bounce around from 700, 1200, 2100, 3000 rpm.
I have tried moving the ground wire to various locations, Bob even had me attach the induction wire to a plug wire with a short section of the shielding removed (thinking the shielding was blocking the signal). Same results... We tried attaching the induction wire directly to the spark plug itself...still the same. I tried a temporarily routing ot the wires outside the window away from any potential interference.
I called the tech service rep from the company that makes them. He said possibly I was getting interference from some source or the unit was defective. Well, I ordered another unit and it gives the same results. And intererence??? On Bob's planes??
At wits end at this point, does anyone have any experience with this kind of instrument?
