Any advice on best source of acid and alodine products? Also a ballpark as to how much of each product is required? I will be importing from the USA, so the most cost effective option is to get the entire quantity in one order...
Acid and alodine
Brad, you sure you want to use alodine? I started to do some parts with it and I did not like the results as well as the complete hassle dealing with it. After an hour long conversation with the tech team at Stewart Systems I am convinced that alodine has seen its day in most applications. If it was me I would go Stewart systems etcher and primer. I am using the water based stuff and I am super happy and I am not dealing with toxic stuff. Clean up is easy and dry time is quick. I bet it's cheaper to ship too as its not haz-mat. That's my two cents FWIW....Dave Bottita The Desert Bearhawk
Project Plans #1299
I am on the fence too. I was planning on alodine to save weight on the LSA but don't really like the idea of it and disposal is a problem. I did buy 4 oz of Henkel Alodine powder from a seller on EBay. I am thinking of going with a primer of some sorts and like the Stewart both because of the lack of fumes and the cleanup. Stewart does recommend a top coat over the primer but I think that anything would be better than nothing.
As for etch you can get that in the big box stores around here. I bought it a Lowes or Home Depot.
Dave
Originally posted by jaredyates View PostThe big box stores will sell it as a paint stripper. Around here it says phosphoric acid in big letters, but you can always check the fine print if you aren't as lucky.
The Phosphoric acid doesn't bother me at all from a disposal standpoint. The alodine is a lot harder to get rid of (legally).
When I was doing the acid etch process ( Phosphoric Acid ) on my Bear Hawk wing parts, It was a hot day out and of course I was all suited up,(Respirator ,Safety Glasses , Rubber gloves , Coveralls , Rubber Boots ) .
While waiting for the etch to start working on one batch of parts, I decided to get a Coca-Cola to drink and for whatever reason I read the ingredients on the can , Wow !! Check the third ingredient from the top !! I was already drinking it !!
