Has anyone looked into using Docol tubing rather than 4130?
From the SSAB website:
Docol® R8 Tube features excellent weldability and has a low risk of welding defects due to the low CE-value, low amount of impurities and a clean oxide-free surface. To reduce the width of the HAZ as much as possible, we recommend that you keep the heat input as low as possible.
For both TIG/GTAW and MAG/GMAW the following filler material is recommended: AWS A5.28 ER80X.-X and AWS A5.28 ER110X.-X. Welding parameters might need to be adjusted.
