To add another data point - I initially kept a small air outlet in the aft fuselage area by the tailwheel attachment point, to allow air to flow through the cabin (and any water to drain out). However this appeared to be assisting CO to be drawn in at the front around the gear struts. I've since found examples on the internet where having an opening at the aft fuselage can create enough low pressure to draw CO into the cabin. During testing I measured CO with the vent open, and also with it blocked off. CO levels were higher with it open, however I haven't measured with the vent open since I lowered the exhaust pipes.
There's quite a lot of info on the web about certified aircraft resolving similar issues, some of them deliberately vent air into the aft fuselage to create a small positive pressure to help prevent CO ingress. It's an area I might revisit but for now I've booked the air outlet off.
