I purchased one of the first tubing kits from Avipro and just finished tacking it together. I likely won't finish weld until Summer is over.
Everything fit together very well and was well documented. I made a couple small recommendations to Mark( careful labeling the tubes so the labels aren't in the way when prepping for welding and to please include a few photos of the factory fuselage to minimize time/errors from interpreting the prints) which I believe he will implement but they are definitely not "critical improvements", just conveniences . Balancing Avipro's price against the the cost of the required tubing and the waste that would go with it I think the price was very fair. Everything was well labeled and while there was one minor hiccup(quickly addressed by Mark) I would definitely take this path again. While it took me about three weekends after delivery to have a fully tack welded fuselage I think I could easily do it in a couple long weekends now(as always "If I knew then what I know now")
(Note this PDF is gone. The info can be found in the "First Flight" post made in FEB2017)
