I know some of you are building the LSA wing by now. I am making this statement in hopes of helping one not make the same mistake I made. I made the wing ribs as per the mylar page # 4 drawing and the compression strut with the aileron bell crank as per plans . I then aligned the spars as per page #17 in the small instruction book. The compression did not align properly so I tweaked it a little and all fell in place. I then did a little rib trimming . At this point I can't help myself, and I am starting to have a bad feeling . I called Bob Barrows and found out the spars are not aligned as per page #17 but by the oblique line on the mylar page #4. I found very little reference to this information . Good luck! Stinger
