Annual inspection 135 hrs. Upon inspection I found rod end bearing GMM-3m-680 jam nut loose and rod end rotating inside push pull rod threaded area. NOT GOOD . Stick movement left and right caused bearing outer surface to make contact with inside of idler bell crank causing it to come loose. Repair: installed spacers , one on each side of rod bearing , however spacers must not touch side of bearing restricting it's movement. Area of concern Red rod end. May also be of interest to Patrol . Stinger
Bearhawk LSA Annual Inspection
bearing joggle 2.jpg I asked Bob about this when I built mine and his response was "Leave it loose and lubricate the threads".
I wasn't comfortable with that so joggled the ears out about 1/8" on either side and use some spacers(made from tubing) so the rod end could be fixed with the lock nut and provide enough rotation without touching the ears.
I faintly remember there being a discussion on here at the time.
Attached is a photo. Upon final assembly, I replaced the washers shown with short pieces of tubing.Last edited by BTAZ; 02-20-2020, 09:59 PM.
I used 3/4 .049 for the vertical with no joggle in my flat plates. I don't normally venture away from the plans but I saw potential misalignment problems. I machined some .190 misalignment spacers for each side.
