Wing dimensions
  • Wing dimensions
    I want to build a wing stand or sling before my kit arrives. Can somebody give me the outside dimensions of the LSA wings as they are shipped in the QB kit, including the thickness of the wing from top skin through bottom skin at the deepest part of the camber? Thanks
    Hi Tom. The over all length of the wing is a little less than 15 ft. Probably closer to 14 ft. With the verticals uprights of your stand spread 8 ft from each other - you would be fine. From trailing edge of inboard section (where flap would be if there was one) to leading edge is 60". From wing top skin to bottom skin at fattest part is less than 10". Hard to measure well with wingtip on. But that should be good enough. Mark
      Thanks for the details Mark!
