Elevator inner hinge detail
  • Elevator inner hinge detail
    IMG_0634.jpg I’m trial fitting my elevators for the first time today and am having trouble. I don’t see how to attach the elevators to the center section. The inner ends of the elevator have small pockets, which seem to need bearings, but the ones supplied in the kit don’t fit inside the pockets. there is very little clearance in there, so there is no room for bearings unless they are recessed.
    Does anyone have any close up shots of their LSA in this area that they can share. I’m guessing I need some smaller bearings that would be bolted together through the fuselage tab, then the elevators slide onto the bearings and retain with a bolt on either side of the horns. Is this correct?
    The inboard ends of the elevator tubes should slip over the bearings. You may have to clean out the paint. If your bearings are too big, make sure there aren't some smaller ones in your inventory somewhere. I have included a picture of what mine looks like assembled. The hardware shown is not the final hardware. The plain nut will be replaced with a locknut.
      thank you for the picture. my bearings are far too large to fit in the pockets. i’ll call Virgil Monday. i think i got the Patrol bearing kit, as this is the second one that’s too big.
      I see the lower bolt and standoff to clamp the halves together. i assume there is an identical one above, right?
        Yes, there is an identical bolt and spacer above to clamp the two together.
