Starting to plan spars. The plans give dimensions for spar width but then says fit to ribs. How close is everyone coming to the given dimensions? I know we had a discussion a while back about what the line on the mylar represented. I thought we decided it was the edge of the form block, Bob had taken into account rib flange thickness and skin thickness. I am starting to think that it is the actual airfoil. My ribs even with joggles are about the same height as the spar as drawn, maybe a little bigger. Aileron and flap ribs are even worse, the rib flanges would go outside spar web flanges instead of the other way around. I guess I will just have a slightly bigger airfoil.
What do you think.
Doug
					What do you think.
Doug
