There is a 3/4" hole below the large oval hole in the center and false ribs. is it better to cut out that hole when you build the ribs or after the ribs are installed to the spar?
3/4" hole in 0.032 center ribs and false ribs
John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uwTags: None
I made the hole after assembly since it's location changes between the wing root and the aileron. I used a step drill bit and a 90 degree drill and drilled before the final wing skin was riveted in place. Here is the way I determined where to drill the holes in each rib location: (link removed due to URL change)Last edited by jaredyates; 01-13-2020, 11:21 AM.
There seems to be a difference between Kit wings and plans build.
By the looks of the kit built wings there is only one size oval hole (small).
On plans build there are two.
The big one in the .025 "ribs allows for the angle of cable to the first .032" rib guide bushing, then parallel to wing root.
Gavin; I bought a set of the avipro ribs, and you are correct. All the center ribs have the smaller size "D" hole at the back of the rib. I'm debating whether or not to cut the 0.025" ribs out to the larger hole or not.
PhilPhil Schaefer
Patrol #073
Working on Spars
