Getting close to final assembly of my Patrol wings and have a question regarding the factory center ribs. When placing a full size (uncut) rib on the mylar it is difficult to get a best fit. If I place the aft end of the rib on the aft spar C/L, the forward edge of the rib is .150 aft of the fwd spar C/L. At this location the fit is pretty good. If I slide the rib fwd, .100 the fit is still pretty good. Trying to check a bent sheet metal rib to a mylar is an exercise in futility. The center ribs have to be accurately located fore and aft to maintain the airfoil shape and I don't want to rely on a couple of pieces of sheet metal clamped to the spar web flanges and the rib flange to locate the ribs position. If I had a measurement from the center of the fwd tooling hole to the aft face of the main spar web I could zero it in. Mark G could you get that measurement from the factory? Anyone else out there confident in the placement of their factory ribs got a measurement?
Thanks
Gerry
Patrol #30 wings
Thanks
Gerry
Patrol #30 wings
