I had an idea for cutting my spar blanks that I wondered would work, and I was certainly not disappointed.
The long edge of my workbench is the factory edge of a sheet of 3/4" MDF. It's never been dinged, cut, mashed, or anything else of the sort. So I figured it would be a good reference edge.
I measured the distance of the cut that I needed, marked on either side of the sheet edge, and aligned the marks with the edge of the bench and clamped it down securely. I chucked up my laminate bit in the router, the same one I routed the ribs out with, and adjusted it so that the bearing would ride along the edge of the bench top.
Cutting one piece of metal versus ten is like butter. Absolutely amazed at the straightness and quality of cut. Of course, there was some waste from the bit, but I accounted for it in my measurements. Tomorrow, we get busy!
