Good morning all,
Typically, when fabricating the spars, one would attach the wing attach plates to the spar web, and then trim to the plates after everything is assembled. I'll use Eric's spar as a visual reference below.
When shearing my spar webs this weekend, I sheared them to the trimmed length (where the web flange would begin), and not out to the tip of the wing attach angle. That, of course, leaves a .032" gap between the attach plates.
So, with that being said, am I able to fill the void with a .032" filler and move on, or shall I redo the webs? A call to Bob is in order, I'm sure, but I wanted to check with you all as well, in case any of you had any engineering expertise to share on the subject.
Many thanks for your thoughts,
Chris
Chris
So now I can move forward without worry!
