Started laying out the main spar tonight, and dug out the bar stock I got some time ago. I forgot how much I bought, so wanted to make sure I had enough.
I had the spar blanks end-to-end and got the tape measure out. Starting from the tip end, I laid out the spreader locations and lightening holes.
I put the the splice plate in place, then started thinking ahead as to how all the pieces fit together. Something felt a little off, though, so I went upstairs to the computer and gave the CAD measurements another glance. Glad I did because I had the spar blanks reversed!
So I got my can of Sharpie eraser out, cleaned things up, flipped the spar blanks, and then remeasured. All came out perfect afterward.
Next task was to match drill all the end plates. I was snapping drill bits left and right. So I slowed down the drill a bit, and also found the deck was about a half degree out of square. I squared everything up, and chucked the drill bit up so it was shorter, with a lot less flex. I didn't break any after that.
. So far, so good, but we'll see in a few months!
