Cut all the spacer bars this evening. What you see is actually double-stacked, with both the front and back parts all together on the front side.
I measured the distance between spar caps, then set a stop block so each is the same length. They are mainly 0.25" x 0.5" 6061 bar stock. I did use some 0.125" x 0.5" where I needed to layer them for special cuts.
The spacer bars in place and trimmed where necessary for angles.
