Patrol Seaplane
    On the float fittings, I decided to weld a u channel and upper and lower gussets at station "E". I used the angle from the spreader bar distances of a set of EDO 2000's and two feet of height from the float top to the bottom of the fuselage. I will use a female threaded aluminum block with a #7 rod end in the upper end of the rear strut. This will allow for the twists and changes as the 3-31/2 degree of attack angle is tuned to the assembly. I don't have any more decent pictures on this computer. In case anyone wants any more, I can load some from my laptop.
