As I am getting ready to bend the spars for my Patrol, I am creating my cut sheets. As I am starting to find out I should have planned better and done this earlier. I was going a bit by the 4 place but there are some significant differences. The flap is just over 8 feet so I will need to cut it out of a 12' sheet. Also all the spars for one wing take up slightly more than a full sheet. I have a question for those that have built it. The fuel tank covers in the 4 place build manual call out 0.032. The patrol plans have 0.025 over that section of the wings. Did people use 0.032 over the fuel tanks to make it a bit stiffer or 0.025 as on the plans. Did the 4 place plans call for 0.032 there.
Aluminum for wing on Patrol
John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uwTags: None
I am trying to make sure I understand what is being talked about here. Are we talking about the "wing skins" in the fuel tank bay area (top/leading edge of wing), or the "tank access cover" on the bottom of the wing? On my Patrol plans the "wing skins" in the fuel tank bay area are noted as .025. The fuel tank "access cover" is .032 (pg. 2, upper left hand corner). That's how I did mine.
Collin Campbell 4-place N370CC, Patrol N180PB
Bolivar, MO
Phil, Thanks. I did not see that. I had thought it was strange that the 4 place called out 0.032 access panel but the patrol had not. I just could not find it though. it does clearly call it out there!!!John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
