Distance to prop flange on patrol
  • Distance to prop flange on patrol
    The plans books show the distance from the datum to the prop flange, I started building fuselage first and do not have the wings, can someone give me a dimension from say the firewall to prop flange so I can build an engine mount. Thanks
    The best I can do is a distance from a vertical center line of the fuselage wing front attach point to the leading edge of the wing of 13.5 inches. You should be able to confirm this from the Mylar wing template.
      Because of the angle of the firewall, it would be hard to give a distance without a starting/reference point. I am in the middle of the fuselage fabric and am unable to provide anything more.
        Thanks, I don't know why I didn't think of that.
