Hello everyone well I officially start building my Patrol I think I'm going to have a lot of questions I consult a lot the forum which is very interresting but i have a big problem i do not speak english but i speak french and german I use a translator really sorry first question someone would have the list of solid rivets for the main spar thank you so much
solid rivet
solid rivet
Hello everyone well I officially start building my Patrol I think I'm going to have a lot of questions I consult a lot the forum which is very interresting but i have a big problem i do not speak english but i speak french and german I use a translator really sorry first question someone would have the list of solid rivets for the main spar thank you so muchTags: None
Welcome, Mike
I am not sure you are going to get an answer - this is not a VANS aircraft where every rivet call out is specified. The bore of the rivet (-3, -4 or -5) can be determined by the size of the hole shown in the plans or by that specified in writing. As for the length, you need one of these - https://www.aircraftspruce.com/catal...engthgauge.php
Then you either need a selection of lengths or get long rivets and a rivet cutter.
Hope this helps.
Mike, the rivet lenghs can be computed by examining the drawings. The forward spar has only -4 and -5 diameters. The rear spar is only -4 diameter. It would be nice if you actually measure your capstrip and spacer bar stock to zero in your computations. Scrounge as many 1/8 and 5/32 cleco's as you can.
Welcome aboard
Gerry
Patrol #30
Mike;
I had nothing better to do one day, and counted up the number of rivets needed. This list covers everything on Plans P. 5.
Splice Plate Rivets (80) an470ad4-7 Cap Strip Rivets (52) an470ad5-5 (128) an470ad5-7 (208) an470ad5-9 (290) an470ad5-11 Attach Angle/Spacer Bar Rivets (20) an470ad4-5 (10) an470ad4-7 (10) an470ad4-9 (20) an470ad4-10 (15) an470ad4-11 (20) an470ad4-13 (15) an470ad5-5 (10) an470ad5-7 (10) an470ad5-9 (25) an470ad5-11 (40) an470ad5-13 End Plate Rivets (36) an470ad5-11 Brooks Cone
Here are the total number of rivets that the plans call for from pages 1 to 6. (I know someone must be saying "Who Counts Rivets?" How else are you going to know how many to order? )An470ad3 -3 = 1300 or .43lbs -3.5 = 600 or .23lbs -5 = 100 or .06lbs an470ad4 -5 = 200 or .18lbs -6 = 600 or .50lbs -7 = 100 or .13lbs -9 = 30 or .05 -10 = 20 or .05 -11 = 40 or .06 -13 = 70 or .12 As I look at the list, realize rivets are cheap, and a cut rivet doesn't buck as nice as a normal rivet. So order some AN470AD3-4's too.an470ad5 -5 = 60 or .10lbs -7 = 130 or ..25lbs -9 = 210 or .45lbs -11 = 350 or 1.0 lbs Last edited by Bcone1381; 02-24-2019, 05:36 PM.Brooks Cone
