I think the hinge drawing on the patrol is not quite right
  • I think the hinge drawing on the patrol is not quite right
    The drawing on my set does not make sense. The hole distance must match the aileron. The same goes for the flap.
    Stan
    Austin Tx
    I see your point... The spar is match drilled, so maybe no one looked closely at the spar detail to check if the dimensions match up.
