Looking for info on a good way to weld closed 3/16"diameter hole that I miss-drilled in a piece of 4130 plate (0.080"). I especially wonder if I need to use a certain filler as the new hole will be drilled partly through the original hole. To make matters worse, I am not a real proficient welder, but I sure try hard. Thanks in advance.
Ivan Haecker QB Patrol #150
