Notes on Forming Patrol Wing Ribs (Plus Side-Bar On Rib Fit to Spars)
    Bob recommends gluing mylar to 032. The mylar has parallel lines representing spars.
    I used a table saw to cut mdf with parallel sides that were 32 -0.032 (patrol spar center line is 32 inches apart).
    I then layed mylar on top of parallel side mdf.
    The parallel lines can be lined up and over the parallel sides of the mdf .
    They should be exact match.
    Drill the tooling holes to forever match the mylar template with the mdf form.
    I would recommend the tooling holes to be a little distance away from spar. I am trying to make sure there are no future issues with rivet to edge distances.
    I use the word parallel to emphasize how the parallel sides are of use during assembly
    image_11022.jpg Those parallel sides are at right angles to the table during the assembly phase.
    Rough mark the top and bottom of the airfoil. Use a jig saw to cut close to the edge. Routers only can take off a little at a time.
    After routing - the mdf form has two parallel sides that are exact, and two routed sides that follow the mylar - aluminum template.
    I even made mdf forms that had notches for the flutes.
    In the picture below form block 3 has two dowel pins holding aluminum horizontally. The rubber holds aluminum down.
    Using a wood dowel flutes can be made. The assembly is held firm with the press.
    LIke Spruceforest above a lever can be used to make sure flanges are 90 degrees.
    Fluting pliers will work. You will find that the first rib will take an hour to flute. Once you get the hang of it , it will only take two minutes.
    Consider investing in a company that makes mdf:
    Stan
    Austin Tx
      Does my heart good to see scratch building skills being passed on. On other hombuilding sites I visit, old timers complain that scratch building is dead and gone. Not among the Bearhawkers.
        I'm just starting a Patrol scratch build and am planning my manufacturing process for the wing components. I have a stupid question regarding bend dimensions on the wing rib flanges. What are the finished dimensions on the bent flanges meant to be?
        On drawing 3 Bob specifies 9/16" flanges bent at 90 degrees however, in the booklet he recommends offsetting the rib form profile by 9/16" from the form block to draw the flat pattern for the ribs. In this case, the bent flanges would be slightly less than 9/16" due to the material consumed in the bend. Furthermore, I don't see bend radius specified for the rib flanges, although I would assume it would be the same as that of the spars at 0.1".
        Thanks for posting your notes and Youtube videos of your build! They've been a great resource.
        -Lane
          I found this youtube video:
          a number 7 drill has about the right radius.
          anyways the radius chamfer is a short cut , a square edge is longer distance.
          If anything, the flange would be the tiny bit longer then 9/16 if you use the washer trick.
          Stan
          Austin Tx
          • #20
            The question we all get stuck on is :
            Are you supposed to cut the master template on the inside or the outside of the line.
            The answer is neither . It is the middle of the line.
            Also I like the spray on 77 for attaching the mylar to a piece of 032.
            I cut to the outside of the line and slowly file to the middle of the line. You must leave some of the line.
            Others might do it differently.
            I also am very fond of 1 inch mdf as compared to the 3/4 inch stuff
            As a rule we all start out with O.C.D. You have to remember we are building the wing with a plastic mallet.
            Stan
            Austin Tx
