Some items came up in lofting the empennage tooling. As expected, I found errors in the paper dwgs when scaling dimentions. Ref Patrol dwg sht 22. Across the dwg sht, the 18" width, the error is about .040 SHORT on the 24" dim or .160 because the scale of the view is 1/4. Doesn't sound like much but it adds up. Witbout adding this adjustment, your horizontal stab ribs will be .160 too short inbd and .125 short outbd. The elevator ribs will also be short. Over the 24" length , the dwg sht is about .060 LONG on the 59" dim or .240 Some dimensions off a factory horizontal stab assembly for some of the rib lengths would help. A measurement between the L.E. tube CL and the spar tube CL where the web of the rib intersects the tubes would do it. It would be useful if someone could check my math. My dwg could be different then yours.
Thx
Gerry
					Thx
Gerry
