Cable tie mounts for wing wiring
  • Cable tie mounts for wing wiring
    I wanted to show what I used to run the cables in the wing I am building. I had used then in the past in some work I had done with an avionics shop. They will mount with a #4 rivet or a screw. You simply loop a wire tie through it to secure the cables. You can also attach a small nylon tube section with a wire tie to make a cable path like a bushing. These items are Panduit LHMS-S5-D LIGHTENING HOLE CABLE TIE MOUNtS. I was able to find some cheap surplus. I did not want to drill the nose ribs and install bushings or install conduit.
    This gallery has 3 photos.
    Very nice.
      That looks slick. Will you be able to reach each one of those through the inspection plates? If one breaks (unlikely for the foreseeable future) or if some new whizzbang item comes out and you need to run a new wire. Thats the only real advantage I can see with the old drill a hole and install bushing approach.
