I am on page 23 of the patrol plans. I am trying to figure out where the rear of the counterbalance formed rib intersects the spar. There is no direct measurement showing.
i tried two ways. neither of which may be accurate enough.
Used a scaling ruler and measured (on the plan) from the top of the rudder down to where the rib attaches. Using that I got 9 inches.
second way--- I measured (on the plan) the angle the rib makes with the rudder post using a machinists protracting square. I got 110.3 degrees. This results in a length of 9+5/8 inched down from top. (extrapolated from the forward tip of the rudder counterbalance- that is the other end of that rib-)
Can someone shed light on how to figure this out ? Not sire how much I can depend on measuring the plans with a scale ruler.......
Hints ?
Tim
Hints ?
Tim
