If you build on a table the holes just end up as indicated above.
If you built in a vertical jig , then the only difference is that you could not use a level like this:
You could just slightly rotate wing in stand so that plumb bob appears to be co-linear. It would not be co-linear you just could not tell with the naked eye.
But you would not find the spars to be level as shown above.
Even though I built on a table, I could have mounted the wing such that a plumb bob would would "look" like it was concentric, But, then I could not have used the level as in the picture. The angle would be whatever it needed to be.
When a wing is riveted on a table it is not going to ever move when you put it in a vertical jig. - Except it could be skewed long way.
In the picture below you can make out a wood shim I use to skew the wing the long way
Even when I used a plumb bob it was just to make sure the wing was not skewed the long way. I expected it to be off a 1/2 inch - I made a washer that was the correct diameter to use the plumb bob in the short direction.
