There is a good discussion going on in another area of the forum on fuel system design that referenced this service bulletin from Glastar. gssb43revb.pdf The service bulletin talks the fuel quantity test and about the degrees of pitch that their aircraft achieves in various realms of flight in order to perform a fuel flow test.
When the fuel flow test is performed, the pitch attitude of the fuselage must set at the most extreme setting that will be achieved in normal flight to ensure that sufficient fuel flow is available in that configuration and to define amount of unusable fuel that exists in each tank.
I do not know nor have I ever seen published what pitch setting that is. What is acceptable for us? What pitch setting results in attaining Vx at 100% power while weighing 1400 pounds? In the descent, what pitch setting would result in a power off glide at Vfe with full flaps?
