I have a quickbuild kit from 2015 (yeah, I already know I should be done by now). I ran into a problem trying to mount the torque tube for the control sticks. I could install the tube on one of the rod end bearings, but the other wouldn't line up. On page 29 of the plans it shows a spacing of 28 3/4". My torque tube appears to have the correct spacing, but the spacing on the fuselage is about 28 5/8". That's way to much discrepancy to easily fix as near as I can tell. Has anyone run into this, or does anyone have any suggestions on what to do? I don't have any welding capability, but it appears that's going to be required unless I'm missing something.
UPDATE:
Mark called me with the solution to this problem (Thanks Mark!). The rear rod end bearing mount is on a horizontal frame member of the fuselage. According to Mark, you "tap" on the cross member to move it into the correct position. In my case I needed to move it aft about 1/8". In practice the "tapping" involved swinging a 10 pound sledge a foot or two into the frame while my wife held the airframe to keep it from taking off on me. I started more gently, but the hammer just bounced off the frame. That is one tough structure. Even with the bigger swings it took quite a few "taps", but it definitely did the trick, and I have the control stick assembly installed now. According to Mark another builder came up with this fix and it was approved by Bob.
UPDATE:
