Is anyone using a prop governor that doesn’t require modification to the firewall with rear mount on an o-360?
Patrol prop governor
The photo below is Bob Barrows Patrol. He is using a Jihostroj Gonvenor. I have one also on my engine and it needs no firewall modification but comes close to the fire wall....3/4 inch? They are made in Czech republic and common on experimental aircraft. The PCU5000 governors are the same unit. When I got mine it was available directly from Jihostroj via an online order.
The Hartzell Governor requires firewall mod. It might be smart to put a round SS inspection hole in the firewall so it can be removed for service without removing the engine. But I dont look forward to cutting a big hole is SS.
I've seen a stainless steel salad bowl from Walmart used in the firewall to provide room for a prop governor.
Maule M5-235C C-GJFK (Sold)
RV-8 C-GURV (Sold)
If anyone is interested, I just bought a Jihostroj governor for my patrol from Whirlwind propeller. They are a distributor, and had the governor in stock. I had been looking for a while, and couldn’t find anyone that actually had them in stock, but yesterday whirlwind did. Im not affiliated with them in any way, but I know finding things in stock can be a challenge these days.
This is what I am ordering for a Lycoming YO-360-A1A and a Hartzell Tailblazer prop. Will let you know if it works out.- Jihostroj P-920-032/A
- pressure to INCREASE
- Takeoff RPM 2700
- Takeoff power at 320deg (all in, low pitch)
- CCW (to increase pitch, pull prop control)
- 866:1 gear ratio
Was this the correct governor? Looking for my application.Originally posted by noema View PostThis is what I am ordering for a Lycoming YO-360-A1A and a Hartzell Tailblazer prop. Will let you know if it works out.- Jihostroj P-920-032/A
- Takeoff RPM 2700
- 866:1 gear ratio
I am yet to fly this thing but installation worked out well.Bearhawk "XHawk" Patrol, O-360, Trailblazer 80", tubeless 26" Goodyears, Stewart Systems. See XHawk Build Log.
