It looks like the kit instrument panel might accommodate the top skin better if it’s canted forward. Either way, I will need to adjust the angle of the top flange since the angle needs to change for the sides vs the top. I notice the top sheet is cut in a curve, perhaps to enable canting the panel. That would provide a bit of a glare shield. Have others done this? If you did or did not do this, how are the sight lines? I’m a fairly tall (6’) person. Looking for recommendations from those who travel ahead of me. Thanks.
Patrol instrument panel: vertical or canted? Opinions?
My panel is vertical, which is the way it came from Mark. I see no reason to change it. It only took a few minutes with a seamer, straight edge and a fluting tool to adjust the flange.The tight radius at the edges of the panel did require a couple of flutes. As for an eyebrow, I currently have 2", which seemed reasonable at the time. Not totally sure if it will stay that long, but it is easier to cut it off than put it on...Patrol QB #312
Buchanan Airfield
Concord, CA
Thanks Lee. Interestingly, my top boot cowl has concave curves cut front and back. The narrowest portion (the center) is just long enough to extend from the firewall to the instrument panel. All four corners would need to be trimmed substantially. I hope I’m not missing something vital here…
B7A0329E-1804-4F53-8F5E-D4C248B848E7.jpgLast edited by Pbruce; 10-10-2022, 05:55 PM.
PBruce, mine was as you described. There wasn't enough material at the center of the top boot cowl piece to make more than about a 1/4 inch glareshield overhang so I cut the whole piece flush with the panel. I can add a glareshield piece later - or not.
PeteYou do not have permission to view this gallery.
The edge hazard would need to be dealt with, for sure. Not sure how effective a 2” glareshield would be anyway in the real world. I guess it would keep direct sunlight off the 7” EFIS at some angles. Im inclined to cut it off and I’ll decide tomorrow whether to go with a vertical or tilted panel. Thanks all.
I fabricated new pieces for the top panel and left the extra just because I could. Not sure it is staying. That edge sticking out is a bit concerning, as has been pointed out by some who have seen it. Not sure the benefits warrant it.Patrol QB #312
Buchanan Airfield
Concord, CA
