My Patrol instrumentation plan is currently something like this: System is built around the basic GRT Sport EFIS. Chosen because it’s compact, bright, cheap, self-contained AHARS, and should be easy to install. It needs an engine information module. I also have a Garmin 796 Era GPS which will be mounted beside the EFIS panel. Txpndr/ADSB will be a Tailbeacon X, which can be controlled on the GRT EFIS. Comm will be a Garmin 220 which interfaces well with the 796. It includes an intercom. No comm panel required. Throttles (2) are mounted inside the left sidewall. Other engine controls will be at the bottom of the panel.
Under consideration is whether to use the remote GRT EIS (easiest) to provide engine functions to the EFIS, or the old LCD display type. The advantage of the latter is that if mounted beside the front seat backrest, below the side window, it could provide full engine instrumentation to the back seater. Disadvantages are more wiring, build complexity, and cabin volume. I have an extra airspeed and altimeter as well, which could be added in the sub panel with the EIS display. But, I have a feeling that once the three pilots in the family are checked out in the plane, we will never need this stuff again. Philosophically, I feel no need whatsoever for any redundancy : attitude? Look outside. Airspeed? See attitude, and use the GPS speed from the 796. Engine control? Sound and throttle position will get me on the ground safely.
I invite any comments regarding the choice before me. Thanks all.
