Started to work with fuel line routing ideas. I have the Patrol Seaplane QB and the left side fuselage door is a mirror image of the standard QB Patrol kit fuselage right side door. I would like to see how others have run the fuselage fuel lines (which takes from fuel tank rear outlet) and runs down the vertical rear former, under the door sill, past the forward door former and to the bracket where the bulkhead T junction is mounted. I've posted my method from the T fitting and past the rear former. Not sure what I am going to do to join the vertical and horizontal runs,but doesn't seem apparent to me it can be done with one singular run of tubing. Also considering running my fuel line inside the frame at the front door former rather than passing thru ...there is adequate clearance from the fuselage tubing and the flap mechanism. If anyone can show how they routed their fuel lines on the right side of the fuselage that would help me with perspectiv/possibilities on the sides of mine. Thanks so much!
Cheers! (Dave from Maine)
