Hi everyone,
We have the test flight programme starting this weekend, and one factor we need to consider it crosswinds. We operate from a controlled airport with only one parallel tarmac & narrow grass vector. We are also located at (statistically) one of the most consistently windy airports in the country, winds almost always blow across the runway vector by at least 20 degrees, although winds are usually steady.
We'll be waiting for the optimal conditions for the first few flights (fortunately the forecast looks ideal), but as we progress deeper into the test flying programme we will undoubtedly be flying a lot of crosswind landings.
As we know each machine is slightly different, e.g. some need brakes to help steer during roll out, others less-so. I am looking for advice on how much work the Bearhawk is in crosswinds, how experienced you were before you felt comfortable flying significant crosswinds regularly, and how much crosswind-component you would suggest limiting early operations to? Also, maximum demonstrated crosswind component would be helpful?
Thanks,
Jonathan
Thanks,
Jonathan
