Elevator bellcrank push pull rod
  • Elevator bellcrank push pull rod
    Is the elevator bellcrank push pull rod supposed to be threaded the same way so you have to unbolt it to adjust it? Seems like you want to be able to adjust it like a turn buckle..
    Travis M
    Kentucky
    Received December 2022
    Builders Log
    Both ends are threaded right hand. You’ll have to disconnect and adjust one end, something you will have to do once at initial setup.
      Being a one time thing that makes sense.
      thank you
      Travis M
      Kentucky
      Builders Log
