I purchased this brake because I had no way to bend spar to rib attach angles. As received, the clamping bar was cut to a sharp bending edge with about 10 degrees of relief for spring back. I tried to bend an attach angle using this setup and got a bend radius of about .050 or so. I could just see light under a 1/16" radius gauge. Plus I could not get a 90 degrees bend. The limited relief for spring back left me at about 85 degrees or so. Too tight a radius for .032 2024-T3 per AC 43.13 which recommends 2T - 4T. So I spent a few hours sanding and filing a 3/32 radius on the clamping bar and added more relief to achieve a 90 degree bend. The result is a very usable tool that nets parts with a perfect 3/32 radius. I'm very happy with the tool and give it two thumbs up. I paid $48 including tax with my 20% off coupon.
Cheers
Gerry
Patrol #30 Wings
Cheers
Gerry
Patrol #30 Wings
