I performed some experiments this morning in my A&P's shop with the wing angles. I found that I *really* like the press brake. Very repeatable, and the bend works from the center, not the edge. When finished, the width of the angle from the flat edge to the outside of the bend is pretty much right on (1/2" in this case).
I tried various pressing points to see where the bend ended up, and was quite predictable. A few examples below:
After I shear them all, I'll bring them back to the shop here at home to bend them. You can see here that the press brake needs a depth adjustment
The spars on the other hand... Practice many, bend once...
