Originally posted by Mark Moyle
Fuel Primer Line
Originally posted by BTAZI built a gascolator from the "plans"(term used very loosely) shown in the LSA build book. I drilled/tapped an extra 1/8" pipe port for the primer next to the main outlet.
As an alternate, when I was looking at various build photos, I saw at least one installation where the primer drew from a T installed close to one of the T's that tie the front/rear tank outlets together. IIRC, it was in the line coming down from the front tank outlet. I expect that would work just as well and might even make routing of the primer feed line easier.
This latter approach is probably the one I would have taken if I hadn't already taken the first approach.
Of course, my system is completely gravity feed so no pump that could "suck air".
If fuel injected, with an engine driven and a separate boost pump, my thoughts would be "What happens if the primer or any of its lines start to leak?" and let that guide the approach.
Leave a comment:
Leave a comment:
Fuel Primer Line
When using the BH gascolator where do you connect the primer line to the main fuel line? Seems like just Ting in would create a potential to suck air into the system. All the systems I'm familiar with there is a primer port on the gascolator but I see the BH gascolator does not have this port.Tags: None
Leave a comment:
