Regarding air compressor for using pneumatic tools, I use a 2hp pancake compressor that puts out 2.7CFM @90psi. It runs my drill and 2X rivet gun just fine. I don't see a need for a big compressor for quite some time.
Yes, for riveting at a minimum. The volume of the compressor depends on what you want to do with it. Die grinders, air-over-hydraulic jack for your press, and paint guns need volume (big tanks). Rivet guns, air drills, nail guns, not as much air volume required. Look at the air requirements for the tools you desire (measured in CFM), and match the compressor to the tool. If there's an electric equivalent, it may be cheaper to do electric if you're being budget conscious. If the CFM requirement for the tool you're considering is low, then pneumatic and electric tools become price competitive.
I'm using electric/battery drills. Rivet gun and arbor press are air.
Eventually you'll need an air compressor. As Brooks mentioned, he's running his rivet gun with a small pancake compressor. Those are quite affordable compared to a larger compressor.
That's the size I have. That and a hose ought to do it. Compressor should have a regulator on it, but low-cost regulators aren't super accurate at lower pressures. Rivet guns are typically operated at about 30-40psi, but I was able to get my regulator to hold pressure pretty well that far down. Some rivet guns also have a better regulator at the handle. That way you can run the regulator on your compressor higher, and use the one on your gun to knock it down to a more appropriate level with better control.
For my press, die grinder, etc, I run it at 90-100psi, but it consumes a fair amount of air and cycles on fairly frequently. 29 gallons should be good for just about everything, except maybe painting. But that's way way far away.
I have the same size, and if its from HFT....probably the exact same compressor. I echo everything Chris mentioned, however I would like to add that spending a little extra on good quality air fittings for your hoses/tools will save you a lot of heartache later. I found the cheap harbor freight fittings to be almost useless. On that note, rubber hoses are easier to work with than PVC, although do cost more.
One last thing that may be location dependent....I always run a good quality filter/dryer on my air line. We get a lot of moisture in the air here in Louisiana and it will help prolong tool life (along with a couple of drops in of oil in the tool before first use each day)
I'd probably just not get your air hose from HF if it's a concern. Go to Lowes or Home Depot instead. I've not experienced any problem with my Menards hoses.
