My dads router is a Stihl (I think it's spelt)
Need advice
Nope, definitely don't want to do that.Originally posted by MNBenny View PostIt's the best I can do. I just am working with very limited stuff this the best I can do unless I start pulling from my flight training money, and I certainly don't want to do that.
. Absolutely, you should work with what you have. Just make smart choices so you don't have to rework things very often.
Northwest, Wisconsin, USA
Just keep at it, whats the worst that can happen? I had a router incident that damaged my router and some wing ribs and that put me off building for a few months, but now Im back at it and kicking myself for the wasted time.
Same here. You'll invariably goof up a few parts. But with that comes experience.
I have another question has anyone tried a,rotary tool to cut their wing ribs and did it work? Just wondering. I'm not so sure the apparatus that my dads router is sitting in will work, but time will tell.
Helpful hints with the router bit, be sure to lubricate the bearing. I did not know to do this until i blew the first one out. Jared Yates suggested that I lubricate and have only blown one other out (I did not lubricate it either). The temp generated from the friction is super high.
Might work pretty well with stability attachments in place, like a router base. The problem with rotary tools is they have no mass, and are therefore pretty unstable. I don't think you'd get quality cuts with one, especially given the typical bits used with them. Routers have really good mass, and that makes them good tools for this kind of job.Originally posted by MNBenny View PostI have another question has anyone tried a,rotary tool to cut their wing ribs and did it work? Just wondering. I'm not so sure the apparatus that my dads router is sitting in will work, but time will tell.
if you have one, take a piece of scrap aluminum, draw a circle on it, and then cut out the circle with your rotary tool. If you're pleased with the quality of the part, then you're good to go.Christopher Owens
My router table is only a little bigger so that should work fine. Like Chris mentioned, remove the fence. I also marked big arrows on the table to remind me which way to feed the material to try and prevent it from grabbing. Im probably the only one but I feel it helps me work a little safer.
I also rigged up my shop-vac to my table to try and catch material as possible. You will soon see why!Steve Nicholson
Lafayette, LA
4 Place Scratch build #1377 in progress (Wings)
