What about using quarter piece of plywood for the temp plate? Might that work instead?
Need advice
Originally posted by MNBenny View PostWould AS&S MDF? Or would a place like Menards or Mills Fleet sell MDF? Also what thickness do I need?Christopher Owens
Originally posted by MNBenny View PostMOrning All,
Chris this going to sound insanely dumb that I ask this so sorry in advance.......When you cut the ribs out from the plans did you cut right on the line, and for the Aileron pocket rib did you leave the dashed line on the form block? It didn't look like it to me, but maybe I have to look again. Also I still can't find the bearhawk manuals. I bought them and downloaded them but can't find them. Will have to check my laptop once,
thank you in advance for the bandwidth.
I made a photocopy of that page of the plans (so I didn't have to cut up my expensive plans) and then measured to make sure that the stayed in scale (some copiers will slightly shrink or enlarge the source material). Then I cut them out to the line and glued them to a piece of MDF. After that, I sand up to the line, or maybe just until the line disappears (but no further). You'll want to make sure you have enough flange to rivet through after they are bent.
~ChrisChristopher Owens
Originally posted by MNBenny View PostDidn't someone say they traced there's to aluminum? I'm going try that. See what happens also what are people's thoughts on increasing the size of the flange? The plans say (I think 9/16) what about full inch or so?
Having a full inch of flange is probably fine, but it adds weight. Maybe compromise on 3/4"?Christopher Owens
Originally posted by MNBenny View PostWhat about using quarter piece of plywood for the temp plate? Might that work instead?Christopher Owens
That looks like a piece of particle-board shelving material to me up in post #33. Is that a correct observation? Particle board isn't bad, you have to have very sharp cutting tools when working with it. It tends to get "crumby" when you work with it because of the large wood particles that are used to make it. I probably wouldn't choose it as my first material, but it could work in a pinch. If I had my choice, I'd stick with MDF.Christopher Owens
Originally posted by MNBenny View PostHow about this for an idea. I traced this from cardboard to Masonite. With my dads help. Also I created a FB page for the build. Just look up Bearhawk 1227Christopher Owens
After some practice, I was able to do around ten at a time. I have a big 1/2" shank router, though. Tailor your sheet count to your available router.Christopher Owens
I was trying to think how Masonite would come into play in the build process. Looking at the shelving, I put two and two together, and think you're talking about Melamine. Now my brain is in a good place again.
