Judging from the photo it might be a trim router which has a smaller base. But even then it's probably got a protective skid plate mounted to the bottom whose holes you could certainly use. Just might not fit his current setup as you suggested. His previous set was a Skil. I wonder if it was a proprietary table/router setup?
i bet you could get it to work with some craftiness, as tbaylx suggests. But you may have creat an adapter of some sort if it's a different sized base.
The skill is a plunge router. Which Im not sure if that matters or not. The table is suppose to be a generic table from what dad said. Crap I might as well just go back to harbor freight and buy a table.
Plunge router doesn't really make a difference. If it won't fit your exsting table, then you may not have a choice without spending a lot of time to make it fit. Maybe HF has table adapters?
Presuming you have wooden bench top, align one of your routing forms on the top and drill through the two jig holes through the table top. On your top form, countersink the holes to accept a flat head screw. Get screws long enough to go through the top form, through the aluminum sheet, through the bottom form, and then through the table top. Then use a washer and nut beneath the table top to squeeze it all together. Then you should able to route from the top, no problem, without snagging on anything.
Here the next set of 5......The mdf pattern will have to be redone as you can see on the aft side of the rib, but that problem I think can be solved by just sanding the ribs. Your thoughts?
When I did mine, I started making the smallest parts first. I made all the Aileron and Flap Nose ribs first. Then I tackled the Flap Ribs. By the time I was making the nose ribs, I felt I had a pretty good handle on things.
