25 feet of 3/8" hose should do you fine unless you have a large shop. The standard fittings usually sold in Home Depot etc are the "M" type and will work for a smaller compressor and rivet guns/air drills etc.
If you want to get a large compressor and plan on running a bead blast cabinet or sandblaster then get 50 feet of 1/2" hose and the larger "V" type hi flow fittings.
If you want a light weight hose and are using the air drill a lot then its nice to have a shorter 1/4" light weight hose as well for maneuverability.
