i am hoping someone has an easy solution to a problem I am encountering. My welded bearing points have a lot of friction. The aileron/ rudder hinges, control stick pivots, elevator bellcrank, etc have excessive friction that will result on very heavy control resistance unless I find a fix. A little lube made the aileron and rudder almost acceptable but the bellcrank for aileron is crazy tight, as is the control stick pivots.
I hope some one has an easy trick to make these swing freely.
