I believe we have different mounts but here are some pictures of what I did I ended up using a 45 degree fitting out of the engine, then used a length of black hose, then transitioned to an aluminum tube to save weight. Naturally there needs to be some rubber because the engine is shock mounted, but I tried to use as much aluminum as possible.
